Page 1 of 2
1996 GK76A mikuni carb model ?
Posted: Sun Aug 22, 2010 10:14 pm
by Karen-Ann
Hi hunny's , had my 76a with 33bhp restriction washers on a power run with a local dynojet tuner and the guy that done the run says the bike is running dangerously lean on fuelling and could burn my valves or pistons out, resulting in a new engine!!! He advised a few things but nothing crystal clear on how to solve the problem..The dyno chart shows it is fuelling correctly from idle to approx 3500 rpm , from 3500 rpm to 8000 rpm it is way out on the graph (under fuelling ). I'll try to get the chart on after i fathem out on how to post it up! Blonde moment!!
Anyhow, the guy at dynojet suggested i get some bigger main jets, he could not find any data in his dynojet book about what size of standard mikuni carb main jets were in as standard so he based it on a GSF 400 mikuni carbs with 100 main jets, so he suggested uprating to 130 on my GK76A......Thing is I cant find any model numbers on my GK76A carbs and if i call a mikuni dealer he will want a carb model number to match some jets up!
Can any of you guys advise me?
Karen-ann xxx
Re: 1996 GK76A mikuni carb model ?
Posted: Sun Aug 22, 2010 10:32 pm
by 4hundread
Hi Karen, as far as I know the carbs are Mikuni BST 32 type, I would hang about for some advice from stripe or someone more kwoledgeable on this before going out and getting bigger main jets though.
si
Posted: Sun Aug 22, 2010 10:35 pm
by stripes1976
If its lean in that part of the rev range raise the needles! 33hp restricted and needing bigger mains? Hell my 80+ hp engine is using something close to 130's.
What is the fueling doing at higher revs? 8k plus?
Posted: Sun Aug 22, 2010 10:39 pm
by Karen-Ann
stripes1976 wrote:If its lean in that part of the rev range raise the needles! 33hp restricted and needing bigger mains? Hell my 80+ hp engine is using something close to 130's.
Hi stripes, wish i could fathem out how to get my picture of the dyno sheet on here...it maybe of help to you..xx
Posted: Sun Aug 22, 2010 10:41 pm
by stripes1976
Have you got a scanner or digital camera? could email it to me then
Posted: Sun Aug 22, 2010 10:48 pm
by Karen-Ann
stripes1976 wrote:Have you got a scanner or digital camera? could email it to me then
whats your email addy stipes and ill send it hunny
Posted: Sun Aug 22, 2010 10:51 pm
by stripes1976
pm sent
Posted: Sun Aug 22, 2010 10:55 pm
by Karen-Ann
stripes1976 wrote:pm sent
yeah got it , just waiting for hotmail adding the picture to mail...btw its from my hubbys email adress xxx
Posted: Sun Aug 22, 2010 11:02 pm
by Variablevalves suck
I will eat my hat if it needed the main upping a 1/4 of what was stated. As stripes say's up the needles to richen up the mid.
Posted: Mon Aug 23, 2010 12:53 am
by Karen-Ann
Variablevalves suck wrote:I will eat my hat if it needed the main upping a 1/4 of what was stated. As stripes say's up the needles to richen up the mid.
Chaps, Gary here (Karen-Ann's hubby) hi-jacking her post!!
Can i give a massive thanks to Stripes for the information he supplied to us! This guy is an asset to the grey-bike forum. Thank you very much for the telephone call Stripes.
Gary & Karen-Ann
