Can't get carbs back on :(
oliherst
Post by oliherst »
Just trying to refit my carbs complete with new rubbers and I just cant do it! :evil:
Been trying Vipers method of fitting the front then shoe-horning the back in but either the front pops out or the backs wont fit, boo!
Anymore tips guys?
wullvfr
Bike owned: zx9r c1
Re: Can't get carbs back on :(
Post by wullvfr »
patience..........persevere like buggery and dont lose the rag,they will go on in the end!!!
when i put mine back on i lined up the front two carbs and forced them in.......make sure they go fully home then push the back two down and back whilst making sure the front two dont come back up....i had a helluva a time getting my carbs back on but in the end....... :D :D
oliherst
Post by oliherst »
Ok I'll keep trying, I just dont wanna ruin my brand new rubbers, it feels like you have to be quite harsh with them!
a bit of rubber grease and warming the rubbers up will sort it out man...
It is a ballache...
fumb
Post by fumb »
Oh man... we've all been there... its tough but they will go on even if you think its impossible... they will.
fastdruid
Regular Member
Post by fastdruid »
oliherst wrote:Ok I'll keep trying, I just dont wanna ruin my brand new rubbers, it feels like you have to be quite harsh with them!
Yep! I've stood on carbs before to try and get them in!
Druid
mick.mh2racing
Post by mick.mh2racing »
How about soaking rubbers in hot water first, softening them a bit.
How hard can it be?
RVFJE
Post by RVFJE »
I'm so impatient with these things that I've used a heavy rubber mallet to get the rears in. Don't hit them with anything is my advice not that anybody would as you are not as stupid and impatient as me. You could break off a piece of the castings which I did and had to buy a new set of carbs.
Using grease or silicon spray should help. I've since seen somewhere here that heating the rubbers is the way to go. I'll put the hairdryer on them next time but I WILL NOT HIT THEM!
In my time I've removed and installed carbs dozens of times on many different bikes. Without doubt these are THE MOST difficult I've ever encountered.
yayoboy
Post by yayoboy »
mick.mh2racing wrote:How about soaking rubbers in hot water first, softening them a bit.
would also try this, also oli try and get the front two located then press down on the back, and use a thin flat screwdriver to guide the rubber aroung the back two carbs, then give them a good push down (your whole body weight!) worked for me with new carbs rubbers
RVFHooligan
Post by RVFHooligan »
Sort of off topic, but since my bike is in bits, if I mount the carbs on the bare engine, will the frame fit over the motor with the carbs attached during reassembly? Seems it would be easier to mount the carbs this way. Anyone?
