my new rvf 400 chain , over done the rivit ?
CRM
Admin NWAA
Admin NWAA
Re: my new rvf 400 chain , over done the rivit ?
Post by CRM »
is the link stiff ? does it look evenly spaces from the back ie link plates line up and the link moves just as good as all the others ?
if so then peen the ends over a tad more and ride.
just curious, what did you use to make it look like that ? i use a whale brand chain hammer to peen hardlinks over, it works too with softlinks like that.
best 85 quid i spent after the abba stand.
code2006
Post by code2006 »
CRM wrote:is the link stiff ? does it look evenly spaces from the back ie link plates line up and the link moves just as good as all the others ?
i think the link moved freely like the others
i used this chain tool
http://www.demon-tweeks.co.uk/Motorcycl ... 09/0/39996
thanks
CRM
Admin NWAA
Admin NWAA
Post by CRM »
this is the badboy i use
http://www.demon-tweeks.co.uk/Motorcycl ... l/409/3507
just punch the ends over slightly, dont use that tool anymore, a small hammer and chisel / punch should suffice.
so long as the links free. slacken the chain, put the link in the middle and check its free, if its not then swop it.
code2006
Post by code2006 »
CRM wrote:this is the badboy i use
yer i have like a punch tool type thing not sure were i got it from tho.
but its is the link safe tho as its cracked? its the over lap part thats cracked
