nc24 motor in nc30
Posted: Wed Aug 04, 2010 8:16 pm
by slo12
Search got me no where, so here goes.
What does it take to put an nc24 motor in an nc30 chasis ?
thanks
Re: nc24 motor in nc30
Posted: Wed Aug 04, 2010 10:45 pm
Some bolts, a 24 system and that should be it...
not sure how the rear routing of the system would go with the shock location etc but something could be worked out....
We've seen a 30 frame holding a 24 motor so I see no reason why it would not work...cannot recall the member name but it might come to me...
You going to get on it Dale? Any reason?
Posted: Thu Aug 05, 2010 10:38 am
Not that hard.
You'll obviously need NC24 wiring loom / CDI box, can't remember off hand which NC30 ancillaries mate up with the NC24 loom, you might have to do a bit of chopping / changing, reg/rec plug is different... but it's not that difficult.
You'll need the NC24 coils too as it has 4 instead of 2.
You might want to use the NC24 exhast system as the NC30 system (which will fit if it's in a 30 frame) is split front rear as opposed to left / right.. (although i'd try the 30 system.. see how it functions)
You could do it in a day if you had all the parts and tools.
Posted: Thu Aug 05, 2010 4:54 pm
by slo12
Thanks for the replies.
I have a rather shagged 24 with a very good motor, and a 30 frame, swingarm, etc. Seems it would be easier to just do a 30 than a 24, especially since parts for 24's are like hens teeth over here, 30 parts are a little easier.
Besides, 30's look and handle much better ;)
Posted: Thu Aug 05, 2010 5:27 pm
Yep, theres a guy on here with a NC30 thats got a 24 motor in it.
You can use the 30 rads for improved cooling (not that that 24 motor gets hot anyway)
You'll need to fabricate a bracket to hold the oil-cooler.
It's not hard, i'd go for it :D
