Revs all over the place....? Help
Sam
Post by Sam »
I recently cleaned the carbs and fitted them. Got it running. I found that after 4k the revs are fine and pick up just fine but as soon as i get off the throttle and get to 4k rpm it doesnt get back down to 0rpm easily and once it gets the needle just moves up and down a fair bit.
What could it be? The vaccum hose has been renewed.
Thoughts?
Thanks.
Re: Revs all over the place....? Help
Air leak between the carbs and the engine.
Happens a lot on old rubbers. While it's running if you blast around the rubbers with brake / clutch cleaner or easy-start (somethign flammable) you'll find the air-leak when the RPM's change
Sam
Post by Sam »
Neosophist wrote:blast around the rubbers with brake / clutch cleaner or easy-start (somethign flammable) you'll find the air-leak when the RPM's change
Whats happen after spraying this stuff if there is a leak? Bubbling?
Harvd
Bike owned: NC35
Post by Harvd »
Your revs should jump up
Neosophist wrote:Air leak between the carbs and the engine.
