Oil Leak from Water Pump drive
beasthonda
Bike owned: FZR 400 RR
Post by beasthonda »
Hi I have an oil leak coming from behind the water pump.
Just had a look and I can see there is a small hole on the rear of the water pump in between the pump and the engine and it looks like that is were the oil is coming from.
Checked the coolent to make sure oil is not getting into that and so far so good.
I am assuming there is a drive shaft that comes from the engine and spins the pump and there is a seal on the shaft.
Has any one had to replace this seal and can it be done without opening the engine??
The bike is a 1990 RR 3TJ
Thanks for any help you can give
Re: Oil Leak from Water Pump drive
I had the same seal fail on my YZF. Seeing as they are prety much the same animals then you need the seal kit for the impeller.
It is easy to replace, once I got the kit I did mine in an hour.
The water pump will be bolted on with 2 bolts adn the whole unit slide out of the casing (where it is driven by the oil pump)
simple job, costs about A£30 in parts and anyone can do it..
(circlip pliers a definite bonus)
beasthonda
Thanks for the info will look into getting a kit.
Just glad the seal should be easy to replace without having to take the engine to bits. :lol:
alfie600
Post by alfie600 »
hi there the small hole is there to stop water going in the oil if the gland fails if oil comes out the small seal on pump shaft gone looks easy to change if u can get one best bet is s/hand pump cheers alf
plodder
Post by plodder »
The 400 water pump has a non replaceable seal. The impeller is pressed/bonded on to the seal and begind that is the casing with the weep hole and the bearing.
I had an impeller come off on a track day and ruined my day because I had no spare and had to abandon it.
beasthonda
Just spoken to the people at Fowlers and they have just said the same as Plodder the seal only comes with the water pump @ £190 odd :o
Has any one got a good water pump for sale.
Or can you get a seal kit as suggested by CMSMJ1
That is harsh!!
I would go with Plodder, he is the FZR guru - I am more of a Honda man myself...and have only had detailed mechanical work on a YZF750 and an exup thou...
plodder
Post by plodder »
Ahh, sweet.
Beasthonda, you have a PM that should solve your palputations
The YZF750/FZR1000 pump is rebuildable as I understand it but good spares are usually cheaper.
beasthonda
Water pump all fixed now
Been running it for a week now without any signs of leaking :P
Got a replacement oil seal from Simply Bearings
12x28x7mm R23 mm Nitrile Rubber Rotary Shaft Oil Seal with Garter Spring R23 / TC for £3.41
If anyone has the same problem!!
Thanks for all the help
Cru Jones
Bike owned: NC35
Post by Cru Jones »
beasthonda wrote: Tue Sep 07, 2010 3:00 pm Water pump all fixed now
I just wanted to say thanks for this. I had been troubleshooting an oil leak behind the water pump and I think the water pump seal (internal) was the culprit and not the external o-ring. I found a Honda part number that's easier in the US to find (91201-MF2-003) that is the same size.
...2T bikes exist and are ready to meet your 4T challengers. - ToraTora
