Page 1 of 6
VFR NC30 Problems
Posted: Fri Jul 30, 2010 3:14 pm
by Claytonbojo
i thort i should open up a new topic ( as people say get your own thred ) so basicly as u no that my bike is running crap as sum people already no the problems are that my lights dim it only revs up to about 6000 to 7000 revs and then cuts out normaly the other things is that i brought a new batery and it goes flat in a matter of days, so i check the VT just be 4 i took it off as it said that it was 10.5 on the VT multimeter so i put it on charge i changed the old petrol tank and put a new one on as the old one was all crushed due to a crash at 60MPH
sum people have been sayin it might be the regulator/rectifer or the alternator i think if anyone has any info on wot might be the problem i will be a verry verry verry happy man
Re: VFR NC30 Problems
Posted: Fri Jul 30, 2010 4:14 pm
as everyone has said.
Check your electrical system.
it is VERY common on these bikes that the Reg / Rec breaks, this stops charging your battery and your battery discharges which stops your bike running, along with your headlights etc.
Somebody already posted a step by step guide as a reply in one of your other posts on how to check the charging system on the bike.
Posted: Fri Jul 30, 2010 4:48 pm
by CRM
Reg rec is faulty or the gene coil windings have shorted.
so replace the reg rec first. and if that still doesnt fix the issue then i bet its the gene.
Also, not being funny but every single post of yours needs to be read around 10 times before i can make head or tail out of it. perhaps its my age, or my lack of street cred or being hip with the kids, however as a tip, you may get more help if people can understand what you write if its not in txt speak innit.
Posted: Fri Jul 30, 2010 4:53 pm
by Claytonbojo
CRM wrote:Reg rec is faulty or the gene coil windings have shorted.
sorry my spelling is not to good i am sorry lol
Posted: Fri Jul 30, 2010 5:07 pm
by Claytonbojo
Neosophist wrote:as everyone has said.
i no i keep posting the same stuff but people moan about me talking about sume thing diffrent so thats why i done my own thred. my battery is fully charged so im about to pute it on the bike and see wot happens ive come across block connectors on the right hand side of the bike with white dust which i think that is corrosion? ive cleaned them, i will check the VT if the bike, isnt up and runnig
Posted: Fri Jul 30, 2010 5:13 pm
by ibby4585
Claytonbojo wrote:CRM wrote:Reg rec is faulty or the gene coil windings have shorted.
It is quite hard to understand matey.We are all willing to help anyone if we can!! Just take your time and read the thread aloud a few times before you post it, I dont think anyone on here has perfect spelling!
Dya gat me bro! yo wickd innit blood! ayyyyyyeeeee!!!
bitchin!!!!!!!!!!!!
Kris
Posted: Fri Jul 30, 2010 6:39 pm
by hardnutdvd
Claytonbojo wrote:sum people have been sayin it might be the regulator/rectifer or the alternator
thats because that is what the problem is 99.9% likely to be....
have you gone through the step by step instructions to test the charging system?? start at the beginning and you will solve the issue
if your new battery has died after a few days it is OBVIOUS there is a charging issue. get the multimeter out again and start from the beginning of the step by step instructions
http://www.electrexworld.co.uk/pdfs/Tro ... G-&-RR.pdf
Posted: Fri Jul 30, 2010 9:34 pm
by Claytonbojo
ibby4585 wrote:Claytonbojo wrote:CRM wrote:Reg rec is faulty or the gene coil windings have shorted.
bitchin!!!!!!!!!!!!
Kris
Kris u crack me up lol ive just got in from doin my bike i fill like poring petrol over it and setting it alight!
(my head fills like its going to exsplode) its still running like sh** so im goin to take the carbs apart tomorrow and if that dosent work then im just going to scrap it! ( just kiddin )
for sum stupid reason the only way i could get the bike to run today was by puting a funel in the fule pipe and then pore it in ive broguth a new tank and checked the tap and its fine so wots stoping from the fule flowing?
Posted: Fri Jul 30, 2010 9:48 pm
by Drunkn Munky
Vacume pipe????
Posted: Sat Jul 31, 2010 1:59 am
This is really like talking to a brick wall.
If your battery is going flat and your lights are dim your reg/rec and possibly altenator are broken, it's a known and common problem with these bikes, it happens to every single one. messing about with other stuff isn't going to help.
If the bike isn't getting petrol properly i said in one of your other threads the vaccumn pipe is the most likely problem, they turn the tap on when the engine is cranked (even if it is set to on no fuel will come out until the vaccum pipe suck the tap)
Check this isn't broken / split
