new gsxr owner...carb troubles lol
Posted: Wed Jul 21, 2010 1:15 pm
hi all just got 1991 gsxr 400(my 1st bike
) its had carbs jetted and balanced supposedly, i got it cheap running on 3, i got new plugs n leads and she was purfect exept leaks from over flows , slow to idle after reving, and would cold start with zero choke/throttle. so i decided aha
'o' rings!!!!
so traced and sourced my own o rings as per tony sleeps measure ments.. but some r slightly different in my carbs
pilot screws are not 3.5x1mm for example.
n e way i have rebuilt them several times now, pilot screw @1.5 (not sp coz no tps! and 32/33mm carbs) cable wound slack so butterflies r closed now my overflow problem in float boals sorted(o rings ther were dead!) bike now screams up2 about 4-6000rpm??? i have had them on the kitchen table about 8 times now maybee more!!!
after 1 rebuild i had her idling perfect but when i reved her a touch she screamed!!!!, it sound asif all 4 carbs are in sync tho when it revs up????i have checked am not catching throttle cable etc b/flies are closed
an yet she seems to scream any ideas ppl cheers joe
