Rvf brakes binding
Posted: Sat Jul 17, 2010 10:30 pm
by steve234
Having problems with the front calipers on this Rvf, basically they work very well but are constantly binding on the discs? Right one seems worse. I have stripped the calipers took seals out cleaned everything and refitted but still the same. There is a small amount of pitting on the piston but this is at the top.
Re: Rvf brakes binding
Posted: Sat Jul 17, 2010 11:25 pm
by rccaulfield
All the springs present in the calipers?
Posted: Sat Jul 17, 2010 11:28 pm
by porndoguk
steve234 wrote:Having problems with the front calipers on this Rvf, basically they work very well but are constantly binding on the discs? Right one seems worse. I have stripped the calipers took seals out cleaned everything and refitted but still the same. There is a small amount of pitting on the piston but this is at the top.
noticed the same on mine today!
mines an NC30 i have stripped them down and gave them a good seeing too. but problem still persists
Posted: Sun Jul 18, 2010 12:31 am
Have any of the bikes been standing?
They should free off after a decent ride.
Also... dont' overfill the brake fluid resevoir.. when the fluid gets hot and expands it'll stick the brakes on...
Posted: Sun Jul 18, 2010 12:50 am
by Cammo
I had front brake binding problems I couldn't solve no matter what I did.
Bought a brand new master cylinder and all problems gone.
This may not solve your issues, but take a look at the master cylinder also, not just the calipers.
Posted: Sun Jul 18, 2010 12:31 pm
by steve234
Thanks for all the replies. It did end up being the master cylinder at fault. Took it apart and gave it a good clean up and brakes work perfectly.
Steve
