Cam Chain Rattle
pearson*
- Bike owned: FZR400RR
Cam Chain Rattle
Well, recently I've been getting a rattle that seems to originate from the right hand side of the bike.
It's a metallic sounding rattle, kind of like a slapping noise.
I'm just wondering what the problems could be, could it be a worn tensioner ie just needing a replacement or should i be looking at replacing the chain itself - is that hard to do?
I have looked at just replacing the tensioner but at £80 for a new one its a bit expensive for what's effectively just a gamble.
I'll try and shoot a little video later so you can see what you think.
Thanks in advance.
Thanks in advance.
Re: Cam Chain Rattle
The cam chain runs in the middle of the engine. Un bolt the tensoiner from the back of the engine (the big nut)clean it and refit see if that works.
Phil Norton
If it's def from the right hand side of the bike, are you sure it's the cam chain?
Other possibilities could be a bit of noise from the clutch. In which case does it still make the same noise when you pull the clutch lever in?
Rattling exup valve? Mine used to do it all the time I owned it. I just left it, as at least it meant I knew it wasn't seized.
pearson*
Will do tomorrow, thanks.Evilchicken0 wrote: The cam chain runs in the middle of the engine. Un bolt the tensoiner from the back of the engine (the big nut)clean it and refit see if that works.
Err, well, i started it up today, let the clutch in and out, the same rattle is there on both occasions, the bike just vibrates more when the lever is let out.Phil Norton wrote: Other possibilities could be a bit of noise from the clutch.
I have also noticed a little clutch slip... could be related?
Thanks.
