3tj fork springs question
- cagiva996
im trying to find some replacement fork springs for my 3tj2/tcat hybrid and keep getting asked if i know what the spring rate is on the standard springs-does anybody know what they are for an 3tj sp ? .ive got a set of freshly rechromed stanchions waiting to go in some freshly painted fork legs with new slider bushes and seals and dont really want to put the 20 year old springs back in.has anybody replaced their springs recently,if so where did you get them from.cheers-steve
				rrsp
- Bike owned: fzr600-,yzf750-,owo1,750
Re: 3tj fork springs question
maxton buddy there is nobody better in my oppinion 3tj springs are all right if you are about 9st wet through with the extra wait & power of a hybrid i would change them,
				barryfzr
I spoke to Richard at Maxton today and ordered a shock for my 1wg/tcat. He was very helpful and confirmed what the Racetech calculator calculated for the front springs my bike...
http://old.racetech.com/evalving/Spring ... bikeid=570
you've obviously got a later model.... but it might give you a pointer as I believe the bikes are much the same weight. I dont know if yours has dampers or cartridge forks mind(I have damper).
Maxton will send you a free spec sheet on your bike anyhow so you can glean a bit there and brace yourself for the cost! ;o)
- cagiva996
cheers guys,but i rang maxton day before yesterday and they said that they didnt want to get involved with supplying any fork springs but to ring them back as a last resort.i guess they can supply a spring set to match the forks they revalve to match the reconfigured damping rates based on rider and bike weight.i did understand where thyre coming from,i spose they dont want to sell something that may not work.but if i could tell them or any supplier the spring rate to start with at leastb id have somewhere to start.they do need changing although theyre still within tolerance,they were made for a the jap market not a 13 stone(without leathers boots etc) lump like me.id love to have them revalved but the budget wont stretch to it-the search continues!!!!!
				barryfzr
okie pokey dug out a 3tj fzr400rr (model starting 4dx-000101) parts pdf and got the following...
spring free length 346mm
limit <341mm
SPRING RATE 6.5N/mm.......0.65kg/mm
....hang on got the sp manual too! (model starting 3tj-141101)
spring free length 359mm
limit <354mm
It should'n be impossible to measure it though I woulda thought.
..I think I know your next question....... yep I can send you a copy if you send us your email.
HTH Barry
limit <341mm
limit <354mm
HTH Barry
				oollit
- Bike owned: FZR400RR 3TJ, RF900R
There was a topic about this on the old forum, which confirms what barryfzr has suggested.
FZR400RR 3TJ
43mm Fork Tubes
Fork Spring Free Length - 346mm
Minimum - 341mm
Spring Rate - 6.5N/mm (0.65Kg/mm)
Fork Travel - 120mm
Oil Capacity - 509cm3 (17.9Imp Oz)
80mm From the top of inner tube, fully compressed without spring.
10w Oil (I used 15w for a stiffer ride)
FZR400SP 3TJ
43mm Fork Tubes
Fork Spring Free Length - 359mm
Minimum - 354mm
Fork Travel - 120mm
Oil Capacity - 433cm3 (15.2Imp Oz)
106mm From the top of inner tube, fully compressed without spring.
10w Oil
FZR400A
Fork Spring Free Length - 412mm
Minimum - 408mm
Spring Rate - 4.4N/mm (0.5Kg/mm)
Fork Travel - 130mm
Oil Capacity - 440cm3 (15.5Imp Oz)
92mm From the top of inner tube, fully compressed without spring.
10w Oil
FZR400SAC
Minimum - 408mm
Spring Rate - 6.6N/mm (0.7Kg/mm)
Fork Travel - 130mm
10w Oil
						FZR400RR 3TJ
43mm Fork Tubes
Minimum - 341mm
Fork Travel - 120mm
FZR400SP 3TJ
43mm Fork Tubes
Minimum - 354mm
Fork Travel - 120mm
10w Oil
FZR400A
Minimum - 408mm
Fork Travel - 130mm
10w Oil
FZR400SAC
Minimum - 408mm
Fork Travel - 130mm
10w Oil
- cagiva996
that is awsome info guys thankyou VERY much its much appreciated.and barry you will have a pm shortly
- Hogdigerdy Dog
don't know what the problem is with maxton atm
i got some uprated springs from them a month ago and they were right on the ball (3tj rr) original spring rate is .65Kg/mm, but for my bulk (14st) they recommended .95Kg/mm and they're the dog's,
they were only too willing to help, give em another try, it'll save you a fortune over the racetech,s, maxton were £100 all in, racetech wanted £120 for the springs+vat+postage, ouch
- cagiva996
im gonna ring back as he did say come back as a last resort.now ive got the sp spring rate i can hopefully get it sorted.i was surprised as theyve always bent over backwards to help with any problems or advice praps i was a bit vague on the phone.
