Thermostat??
Sam
Thermostat??
Post by Sam »
My thermostat was leaking so i bought replacement seals for it. I gave it a really good clean and tried to put it back together but the bolts are not holding on to the bottom of the thermostat housing. Anyone else have this problem? Can i get away using longer bolts and a nut?
Thanks.
BTW, before it all goes back on the bike, how can it test the themostat to check that it works properly?
Delboy
Re: Thermostat??
Post by Delboy »
Dunno 'bout the bolts but to test a thermostat put it in a saucepan of water and put it on the hob and observe. Even new ones have been known to fail.
Sam
Re: Thermostat??
Post by Sam »
Thanks i'll give that a go :grin:
superlite
Bike owned: TLS, LB80 x 2
Re: Thermostat??
Post by superlite »
Sam wrote:the bolts are not holding on to the bottom of the thermostat housing. Anyone else have this problem? Can i get away using longer bolts and a nut?
The bolts go through the bottom and thread into the top of of the housing :whistle:
But if your threads are buggered, then nuts would do the job.
'Take it to the Back'
