engine probs 3tj 4dx
- Bike owned: 954 blade,
well took the carbs etc off & all the plugs out, spins over nice & quiet till I put a compression tester on number 2 cylinder then I get a knocking sound, doesnt really happen to any other cylinders, does that seem like big end bearing ?
Re: engine probs 3tj 4dx
I though they ran in shells
poss new shells then? I,ve a good bottom end on a spare engine I might swap over, nowt ever straight forward for me is there lol.
- Bike owned: fzr600-,yzf750-,owo1,750
the bottom end doesnt come off that easy its a full re-build you will have to do,as the shells wont be correct for the crank,you have to do a full strip down to replace the shells,on a race bike you leave the 2 bolts out which are under number 2+3 pistons ,so you can take the bottom end off with out taking the head & pistons out ! (giving away all my secrets )
Thanks rrsp, I,m over the moon now.
I,ll take the sump off later & have a peep.
- Kayla850
- Bike owned: Sunn Tzar S2
Hi Mark,hipringle wrote:Thanks rrsp, I,m over the moon now.![]()
Sorry to sound like a vulture
www.projection-racing.com
www.pjcfasteners.com
Kayla850 wrote:Hi Mark,hipringle wrote:Thanks rrsp, I,m over the moon now.![]()
Sorry to sound like a vulturebut if the engine's a write off and you want to move the whole rolling chassis on, I'll have it :) I want a 3TJ to try the TRX engine in
I,d like to try & get it sorted one way or the other Kayla, if I dont have any sucess I,ll let certainly you know me dear, ta.
