new to the forum!! hey! what shock fits the 1wg?
addiction269
Post by addiction269 »
need to replace a beaten old rear shocker on a 1wg, what options do i have, any help appreciated!
Re: new to the forum!! hey! what shock fits the 1wg?
Post by Evilchicken0 »
Use the later red spring R6 shock, Change the spring for a lighter one. Round off the bottom mount to fit the 1WG's linkage and pack the top with washers or a spacer each side.
You need to fit different dogbones I believe standard SV650 will work.
addiction269
Evilchicken0 wrote:Use the later red spring R6 shock, Change the spring for a lighter one. Round off the bottom mount to fit the 1WG's linkage and pack the top with washers or a spacer each side.
sounds good to me! cheers
