Side Stand Switch
RVFJE
Side Stand Switch
Anybody know how to remove this so the engine still starts?
Can you just disconnect the plug at the main loom in the fron of the bike?
mick.mh2racing
Re: Side Stand Switch
Think if you disconnect it, bike won't run as it'll think stand is down. You need to remove connector and fashion a connector to effectively join the two wires together. Depends on how permanent you want it to be you can just cut the wires behind the conector and solder them together. Otherwise make a connection to fit into the connector.
How hard can it be?
Yeah as Mick says, just join the 2 wires together.
Carlos
The green and green/white wires I'm guessing?
RVFJE
OK I'll try that. Thanks
