33bhp?
trev
One Hit Wonder
33bhp?
Post by trev »
hey guys just looking at a fzr400 and hoping to buy it, its a 1986 genesis, are there 33bhp washers available to buy for those, because i have been on fi international website and they only have fzr400 1990 onwards?? a speedy reply would be nice, thanks guys
pearson*
Bike owned: FZR400RR
Re: 33bhp?
Post by pearson* »
Yes, they are made for the 1wg.
If you post up in the wanted section someone may have a set you can get second hand (and probably save £150 in the process).
You don't need the certificate that FI International give you so my advice is just have a look on eBay and on here for a second hand set.
Hope this helped.
0G0R3K-15
Bike owned: Yamaha FZR 400 Genesis 1986
Re: 33bhp?
Post by 0G0R3K-15 »
Just to not create another topic. has anyone got sizes of all of these restrictor kits? I got a friend at Air Conditioners factory who can easily cut anything from steel, alu etc of any thickness so why spend money on it while I can have it for bear or two :D
pearson*
Re: 33bhp?
Post by pearson* »
....so why spend money on it while I can have it for bear or two :D
How many bears do you have lying about ;)
I think measurements have been posted up somewhere before, il have a quick look in the morning for you.
Which model would you need the dimensions for?
0G0R3K-15
Re: 33bhp?
Post by 0G0R3K-15 »
I got the same as trev
1986 Yamaha FZR 400 Genesis
pearson*
Re: 33bhp?
Post by pearson* »
400greybike.com/forum/viewtopic.php?f=35&t=2833&st=0&sk=t&sd=a&start=30
There we go, look on page 4, last post, should help.
0G0R3K-15
Re: 33bhp?
Post by 0G0R3K-15 »
Thank u. How thick should they be by the way? 1mm? 2mm?
MrTadSlow
Bike owned: CRM 250 CBR600 YAMAHA FZR 3TJ
Re: 33bhp?
Post by MrTadSlow »
I may know a chap who mite be able to help, I'll be going over his way soon
pearson*
Re: 33bhp?
Post by pearson* »
I believe they should be 1mm thick.
If your making them, try using a non-oxidizing metal such as aluminum :)
Good luck if you have a go at fabricating some, we'll see how they turn out :grin:
0G0R3K-15
Re: 33bhp?
Post by 0G0R3K-15 »
Just the problem is even if I make them I dont know any dyno in sunderland
