NC31 EXHAUST
Posted: Sat Jun 05, 2010 9:12 pm
by bridgeman
hI gUYS
can any one tell me can i fit any other nc down pipes and end can to my nc31 1992 super four.
would like to loose the rusty one piece unit
Re: NC31 EXHAUST
Posted: Mon Jun 07, 2010 11:27 am
by Bodhi
Hey, from what I'm aware of there isn't any of the other NC systems that will fit onto the SF. If you've the '92 SF though your system should be stainless steel and so you should at least be able to take it off and sand it all back and get rid of the rust. I've got the Version R which has the painted steel headers which pretty much rust away to nothing, so you should be in a better position for getting the rust off at least. There's very few aftermarket systems available in the UK and you'd need to be looking into the likes of something from Japan to replace it.
Or else there's PredatorMotorsports.co.uk, who do a replacement system for over £400 or so I think, or else
http://www.cmsnl.com/cb400sf-exhaust-sy ... =cb+400+sf
http://www.overracing.com/shop/ who also do a system for the SF.
Those are about all the options I've managed to come across anyway. Hope that's of some help.
Re: NC31 EXHAUST
Posted: Mon Jun 07, 2010 1:55 pm
by Adicolor
Check ebay fella, i'm almost certain there's someone on there from Japan doing a full stainless system for around £200 ! Might be worth a look !
Re: NC31 EXHAUST
Posted: Tue Jun 22, 2010 5:46 pm
by Andy C
Adicolor wrote:Check ebay fella, i'm almost certain there's someone on there from Japan doing a full stainless system for around £200 ! Might be worth a look !
Got a link?
Re: NC31 EXHAUST
Posted: Wed Jun 23, 2010 6:28 pm
by Andy C
This is going for £230 delivered, sure you could put a different slip-on and have yourself a race system? 304 Stainless Stell too....
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
Was thinking a zx6r b1h/b2h slip on might be the same diameter?
With a 2nd hand can off ebay it could be done for £300-£350 i think, opinions?
Re: NC31 EXHAUST
Posted: Wed Jul 14, 2010 6:43 am
by bridgeman
Andy C wrote:This is going for £230 delivered, sure you could put a different slip-on and have yourself a race system? 304 Stainless Stell too....
PIPE ALL DONE TOOK IT OFF WIRE BRUSHED HEADER PIPES AND WASHED DOWN WITH WONDER WHEELS CLEANER. ALL RUST GONE.!!!!!!! CUT OFF OLD END CAN . FITTED NEW LINK PIPE AND A STUBBY END CAN.
LOOKS AND SOUNDS GREAT BIKE RUNS OK DID NOT HAVE TO MESS WITH CARBS.
Re: NC31 EXHAUST
Posted: Thu Jul 15, 2010 7:08 pm
by Superjack44
Where did you get the new link pipe?
Re: NC31 EXHAUST
Posted: Fri Jul 16, 2010 10:05 pm
by bridgeman
Superjack44 wrote:Where did you get the new link pipe?
got it from my local breakers they had a box full of odd sizes etc.
link pipe fitted ok with a clamp then fitted a s/h end can made a bracket and job done the job only took about two hours .
Re: NC31 EXHAUST
Posted: Sat Jul 17, 2010 11:17 am
by Superjack44
bridgeman wrote:Superjack44 wrote:Where did you get the new link pipe?
Must have been having a few senior moments
, that never occurred to me
