NC24 Battery. What size.
Greg78
Bike owned: Honda VFR400 NC24.
Post by Greg78 »
Hi all.
I bought a battey nearly a year ago, the one the shop recomended for my bike. It never seamed to fit right in the battery carrier. It's as if It should have a tall slim battery and not the quite square (from side view) one which I have ballenced in there now.
Anyway I have neglected this battery and any attempt to reserect it have failed so it's time to buy a new one.
What do you guys in the know recomend?
Also if it the square type fitting battery I need, is there something missing from the carrier to make it not sit right?
Thanks in advance,
Greg78
P.S. If I could work out how to attach a picture then I would as it'd probably make more sence than my ramblings!
Re: NC24 Battery. What size.
No it's tall and thin, you have the wrong battery.
9 Ah VARTA 509 015 (YB9L-B, 12N9-3B)
Most people will refer to it as a YB9L-B
http://www.tayna.co.uk/YB9L-B-12N9-3B-P790.html
£20 inc vat for a Varta one.. good battery that.
You'll need to buy some acid (£7.00) too.
If you click on 'Specs' you'll get the dimensions of that battery which is the proper one, to compare to your existing battery.
Changes are you most likely have an NC30 battery on there.
Greg78
Post by Greg78 »
Thanks for that info, I didn't think it looked right.
No trouble :)
Get a named battery.. Varta for £25 (inc acid) is probably around what you'll pay for a cheap on :)
Old Painless
Post by Old Painless »
I got a Bosch battery from halfords, the filling bottle was poor. You have to fill each cell individually rather than all at the same time. Was not impressed. Did the job though, seems good quality.
Old Painless wrote:I got a Bosch battery from halfords, the filling bottle was poor. You have to fill each cell individually rather than all at the same time. Was not impressed. Did the job though, seems good quality.
Bosch batteries are ok, wasn't aware they did a YB9L-B battery though, or was it you that has some other battery on there?
Old Painless
Im not sure what it is i have got but it works, i will be in the garage for a while this afternoon working over the cam timing so i will take note of the number and let you know.
Old Painless wrote:Im not sure what it is i have got but it works, i will be in the garage for a while this afternoon working over the cam timing so i will take note of the number and let you know.
Ok cool :)
If you can't fathom out the cam timing i'm sure I can point you in the right direction anyway
Old Painless
The battery carries the following information.
Bosch
12v
9Ah
80A (EN)
509 14 (DIN)
509 014
Its the next one up in the range from this : http://www.halfords.com/webapp/wcs/stor ... yId_165697
Looks like mine isnt stocked anymore oddly.
Old Painless wrote:The battery carries the following information.
Bosch
12v
9Ah
80A (EN)
509 14 (DIN)
509 014
oh it's a 509 14.. The terminals are the wrong way around?
Postives on the Left when looking at the battery? It should be on the right.
http://www.tayna.co.uk/VARTA-509-014-YB ... 1-P26.html
Same as that but bosch?
