nc30 coolant
Posted: Sun May 30, 2010 3:28 pm
can anyone recomend a good brand of coolant or is the cheap crap the same and how much will i need as i am changing both rads.
http://www.400greybike.com/forum/
Not so much make.myheroduane wrote:can anyone recomend a good brand of coolant or is the cheap crap the same and how much will i need as i am changing both rads.
Royal Purple :-) I use that before.. it is goodvfrman wrote:I like Engine Ice. Also, Royal Purple sells some stuff that is awesome.
Ah I guess that the pre-mixed stuff?Deviant400 wrote:rock oil motorcycle coolant ,after i flushed system through holds about 2 litres plus a bit in the expansion overflow bottle so bout 3 litres will do ya so you will have plenty spare for top ups
sorry yep premixed , less fuss tip in straight from the bottle job donePosted: Mon May 31, 2010 12:56 pm
The concentrate should be diluted 50/50 :)
