nc30 coolant
- Bike owned: nc30
nc30 coolant
can anyone recomend a good brand of coolant or is the cheap crap the same and how much will i need as i am changing both rads.
Re: nc30 coolant
Not so much make.myheroduane wrote:can anyone recomend a good brand of coolant or is the cheap crap the same and how much will i need as i am changing both rads.
Focus on contents.
You want a Silica (sand) FREE coolant.. lots of car type antifreezes have tiny particles of silica in them to keep the system clean inside.. this works like a mild abrasive.. this will buggar your water pump up on the VFR.
Your LBS should have some. I brought Rock-Oil last time.. my local shop splits it and sells it by the litre.. was about £7.50 for two litres.. more than enough for the as you want to dilute it with DISTILLED water at 50/50.
- vfrman
- Bike owned: NC30, 1098s
Re: nc30 coolant
I like Engine Ice. Also, Royal Purple sells some stuff that is awesome.
Re: nc30 coolant
Royal Purple :-) I use that before.. it is goodvfrman wrote:I like Engine Ice. Also, Royal Purple sells some stuff that is awesome.
- Deviant400
Re: nc30 coolant
rock oil motorcycle coolant ,after i flushed system through holds about 2 litres plus a bit in the expansion overflow bottle so bout 3 litres will do ya so you will have plenty spare for top ups
viewtopic.php?f=62&t=27307
Re: nc30 coolant
Ah I guess that the pre-mixed stuff?Deviant400 wrote:rock oil motorcycle coolant ,after i flushed system through holds about 2 litres plus a bit in the expansion overflow bottle so bout 3 litres will do ya so you will have plenty spare for top ups
The concentrate should be diluted 50/50 :)
- Deviant400
Re: nc30 coolant
sorry yep premixed , less fuss tip in straight from the bottle job donePosted: Mon May 31, 2010 12:56 pm
