a guide how to fit a gsxr k8 shock to your 3tj
- cagiva996
found this whilst browsing the web and thought i should share it.its a guide how to fit a gsxr k8 shock to a 3tj with a different way to bring the shock up to length, and it gives you adjustable ride hieght too.i like this!AND it will give us all another option when weve finnally bought up all the 2co r6 shocks
http://www.fzrarchives.com/ipb/index.ph ... ntry428771
Re: a guide how to fit a gsxr k8 shock to your 3tj
Interesting huh ?
BDK Racing make a ride height adjuster, I'm sure they'd make one a bit longer if they were asked to. This could make this an easier mod than using the R6 shock as the spring rate seems closer to the 400's standard setting.
One of the guys seems to dis it a bit saying about the shock length being either 345 or 335, that's a bit of a red herring. If the bike sits at the wrong height when the shock is properly set up you'll simply change it on the top mount. With a bit of experimentation they'll have some base settings making the whole thing easy to do.
- Kayla850
- Bike owned: Sunn Tzar S2
That's a good idea, but maybe the R6 reservoir will foul on the swingarm if you move it down too far. You'd have to move the R6 shock down another 25 to 30mm or so from where the GSX-R shock is moved to.
www.projection-racing.com
www.pjcfasteners.com
pearson*
- Bike owned: FZR400RR
Does anyone know what the spring rate is on the k8 shock at all in comparison to the FZR shock at 325lbs?
The 3TJ is sprung soft as standard, and the shock itself is going to have different charicturistics anyway ... your not comparing like for like
pearson*
ahh...
I am wondering, as being a 10 and a bit stone guy, i'm not exactly that heavy, therefore the r6 shock would probably need a spring change for me (and more costs....
Just kinda wondering if this would be a better (or cheaper) option?
oollit
- Bike owned: FZR400RR 3TJ, RF900R
I was having a poke around the 'net when i stumbled across a thread about fitting a shock into an SV650, it had a list of different shock lengths which looked interesting...
Make Model Year Shock Length
(mm) Shock Stroke(mm)
Suzuki Bandit 600 2000-2004 319 55
Suzuki Bandit 650 2005 319.5 65.5
Suzuki Bandit 1200 1996-2000 306 64
Suzuki Bandit 1200 2001-2005 320 (+6/-0) 61
Suzuki GSXR 600 1992-1993 312 (+12/-0) 67
Suzuki GSXR 600 2001-2003 325.5 (+6/-0) 74
Suzuki GSXR 600 2004-2005 332.5 (+6/-0) 74
Suzuki GSXR 750 1985-1987 290.5 61
Suzuki GSXR 750 1988-1991 312 (+12/-0) 67
Suzuki GSXR 750 1992-1995 312 (+12/-0) 67
Suzuki GSXR 750 1996-1999 356 (+6/-6) 79
Suzuki GSXR 750 2000-2003 325 (+6/-0) 74
Suzuki GSXR 750 2004-2005 332.5 (+6/-0) 74
Suzuki GSXR 1000 2001-2002 329.5 (+5.5/-0.5) 74
Suzuki GSXR 1000 2003-2004 332.5 (+6/-0) 74
Suzuki GSXR 1000 2005 319 70
Suzuki GSXR 1100 1986-1988 315 69
Suzuki GSXR 1100 1989-1992 312 70
Suzuki GSXR 1100 1993-1998 312 70
Suzuki Hayabusa 1999-2006 330 72
Suzuki SV1000/SV1000S 2003-2007 332.5
Kawasaki ZX6R 2003-2004 340 (+12/-0) 72.5
Kawasaki ZX6RR 2003-2004 340 (+12/-0) 72.5
Kawasaki ZX6R 2005 335.5 (+12/-0) 64.5
Kawasaki ZX6RR 2005-2006 330 (+12/=0) 63.5
Kawasaki ZX7R 1996-2001 350 (+12/-0) 75
Kawasaki ZX9R 1994-1997 348 79
Kawasaki ZX9R 1998-1999 330 (+12/-0) 69
Kawasaki ZX9R 2000-2001 338 67
Kawasaki ZX9R 2002-2003 338.5 67.5
Kawasaki ZX10 1988-1989 314.5 67
Kawasaki ZX10R 2004-2005 338 (+7/-5) 69
Kawasaki ZX12R 2000-2005 338 (+7/-5) 67
I have highlighted the best looking options of the Suzuki shocks, might be worth a gamble on any of those 2 slotting straight in the 3TJ without any modifications, or with just a adjustable top mount. I am only assuming that the shock length measurements are eye to eye.
oollit
Tha factory spring rate for the GSXR K8 shock is 9.5 kg/mm or 532 lbs/in in old money.pearson* wrote:Does anyone know what the spring rate is on the k8 shock at all in comparison to the FZR shock at 325lbs?
MrTadSlow
- Bike owned: CRM 250 CBR600 YAMAHA FZR 3TJ
That all sounds good.......I'm now thinking of selliing the new red spring R6 shock becase no one has a
adaptor they can sell me "Marb included" the F@?>, & getting hold of a rrsp one !!
Can anyone give tell me much about the rrsp shock Please.
I had an SP shock but it needed a rebuild. I sent it off but they needed a bump stop and couldn't find or make one. The rod is an odd size too.
An ordinary shock costs about £80 to rebuild, so you might as well look for a different shock and mod the fitting. 10mm is a nut and a couple of washers on a bolt
