bar ends nc29
natnif
bar ends nc29
Post by natnif »
Hi,
the previous owner had a small spill off my cbr and he snapped one of the bar ends off. Now I have bought new bar ends but they aren't honda. I've been told they will fit, you just have to get the "innards" out of the handle bar first....so I took off the bar end, put the screw back through and got a vice grips at it but no joy. Is there an easy way to do this?!!!
Thanks!
leopard_pagan
Bike owned: used to have a NC29
Re: bar ends nc29
Post by leopard_pagan »
it would be far easier to buy Honda specific end weights...
LozVTR
Re: bar ends nc29
Post by LozVTR »
even if you bought honda ones it would not matter if the old bar end had snapped off in the thread. they still wouldn't fit.
Inside of the handlebar you will have a small locater lug which holds in the threaded section. The only way I know how to do this is to remove the outer plastic sleave (bit under the grip) and look at it that way. Unless anyone else knows an easier way?
leopard_pagan
Re: bar ends nc29
"so I took off the bar end, put the screw back through"
he can get a bolt back in.....
LozVTR
Re: bar ends nc29
Post by LozVTR »
lol...Sorry LP, it had been a long day and all that. No offence meant if I came across harsh.
teach me to read the post properly before answering...
leopard_pagan
Re: bar ends nc29
np.. i do feel for the chap whos going to try and change the bar ends.. i didnt bother in the end as i saw what a polava it would have been.
binge
Re: bar ends nc29
Post by binge »
Ive removed the inner weights out of my Clip ons. I did this by screwing a bolt into the threaded part, Vice grips and just really going for it.
They do come out as they are only held in by 2 rubber O rings, which are around either end of the inner weight, And fill the gap between this and the inner of the Clip on.
So my Clip ons are completely hollow, And im just running a pair of after market Motrax Bar ends in black. They aren't even weighted, Just flat bar ends.
Look sexy as with my Renthal Medium Grips! :)
Good luck matey, The "inners" do come out though, Just have to really tug on them.
leopard_pagan
Re: bar ends nc29
get a m8 to hold on to the other side of the bike.....
binge
Re: bar ends nc29
Post by binge »
leopard_pagan wrote:get a m8 to hold on to the other side of the bike.....
Thats one way around it.
Or do what I did if you can, Take the clip-on completely off, Strip the switch gear and throttle slide/grips off so you dont damage them. With the help of a vice, a hammer and some gentle smashing. You will get them out. ;)
natnif
Re: bar ends nc29
Post by natnif »
thanks guys, I haven't had a chance to look at it again yet but I might get it done tomorrow....
