Page 1 of 2
Brake lines What do you use?
Posted: Sun May 16, 2010 5:28 pm
by skinnydog0_0
Hi all,
I am currently using HEL brakelines on my rvf and i have blead them 3 times and they still seem a little soft/spongy.
I used to use Goodrich lines on the VFR and never had a problem with bleeding or the feel.
Has anyone else had similar feelings from their HEL lines, or am i doing something stupid :?
I am sure that i am bleeding them correctly, i do one caliper at a time and dont use a kit (do it the old fasioned way). But the lever seems to always pull back to the handle bar, i don't remember having this with the goodrich lines
I have tried leaving them over night, with a cable tie round the lever with the brakes 100% on and the resivoir cap loose. It seemed a bit better but still not quite right :?
Any advice much appreciated
Re: Brake lines What do you use?
Posted: Sun May 16, 2010 5:47 pm
by Old Painless
You have air in the lines, master cylinder or calipers. I have used HEL lines and they are as good as any other.
Posted: Sun May 16, 2010 6:06 pm
by Daz H
Hel are quality lines; have you cracked the banjo bolt at the master cylinder? There could be a little bit of air in there.
Posted: Sun May 16, 2010 6:48 pm
by skinnydog0_0
Thanks, i must be doing something wrong. I will start from fresh and check that the banjo bolts and copper washers are clean and everything is as it should be.
I agree about the HEL lines, the build quality is very very good.
Is there any way of air getting in through the master cylinder or the rsivoir connection?
Posted: Sun May 16, 2010 9:10 pm
by Daz H
As long as everything is working as it should and you have fluid in the reservoir no air should be able to get into the system anywhere. As you've said, Start again and check everything! I have had it where I just couldn't bleed it up for ages, left it over night then it sorted it's self out? Bleeding brakes sucks :grin:
Posted: Sun May 16, 2010 9:19 pm
by skinnydog0_0
Yes i will check everthing again Daz. before i take it apart though I think i will try the brakes on 100% again and leave them on over night, seemed to help a little last time. :pray:
Posted: Sun May 16, 2010 10:36 pm
by cbr400rrn
skinnydog0_0 wrote: I have tried leaving them over night, with a cable tie round the lever with the brakes 100% on and the resivoir cap loose. It seemed a bit better but still not quite right :?
Never heard of leaving the reservoir cap loose as air can then get into the system, remember it is supposed to be a closed system (No air can enter it.)
Just keep bleeding them it can take quite a while
Posted: Sun May 16, 2010 10:47 pm
by Cammo
Daz H wrote:have you cracked the banjo bolt at the master cylinder? There could be a little bit of air in there.
What Daz said ^
You might need to bleed the master cylinder. You can do it just as you do the calipers: pump the brakes up and crack the bolt open, tighten up and relase the lever. I wrap a rag around it so fluid doesn't get everywhere.
You can also buy master cylinder bolts already with bleed nipples.
Posted: Sun May 16, 2010 10:53 pm
by Andy_998
You should start the bleeding from the master cylinder down if u are usin the old fashion method. Make sure ur brake res is kept topped up, to bleed it at the master cylinder pull in the lever back off the banjo bolt on the master cylinder then re tighten and release the brake lever slowley. Ensure u have plenty of rags around the area as brake fluid will go everywhere. Repeat this process till the brakes start to feel much better then bleed as u already described at the calipers. The brakes should be spot on then.
Haha sorry beat me to it!!!! :whistle:
Posted: Mon May 17, 2010 7:11 pm
by skinnydog0_0
Andy_998 wrote:You should start the bleeding from the master cylinder down if u are usin the old fashion method. Make sure ur brake res is kept topped up, to bleed it at the master cylinder pull in the lever back off the banjo bolt on the master cylinder then re tighten and release the brake lever slowley. Ensure u have plenty of rags around the area as brake fluid will go everywhere. Repeat this process till the brakes start to feel much better then bleed as u already described at the calipers. The brakes should be spot on then.
Thanks guys, will start again from scratch, and bleed the master cylinder too :smile:
