Cutting down end can
Posted: Sat May 08, 2010 9:07 pm
by w00dzy
Just wondered if anyone has cut down an end can before and would be willing to do mine :grin:
Might give it a go myself tomorrow not sure though.. how easy is it..
Re: Cutting down end can
Posted: Sat May 08, 2010 9:53 pm
by Drunkn Munky
Easy mate, drill the rivets, cut too length, drill and rivet back together. Is it damaged then?
Posted: Sat May 08, 2010 11:51 pm
by w00dzy
Not damaged, but think it would look nicer if it was shorter.. plus its running slightly rich and having a shorter pipe may sort it ;)
Posted: Wed May 12, 2010 10:33 pm
by w00dzy
Managed to do it ok.. took about 5 hours in total.. main problem was putting it all back together after as after clamping the can in a vice bent it slightly. Bike does run slightly better with a bit more growl, I can almost hear the exhaust over the induction noise if I turn my head back ;)
Here are some before and after shots..
What do you think? Me likes.. :grin:
Before....
After....
Posted: Fri May 14, 2010 2:49 am
by kevin wilson
is tidy,,wot areya going to start chopping at next :grin:
Posted: Fri May 14, 2010 7:04 am
by zul_cbr
nice and looks good! :plus:
Posted: Mon May 17, 2010 1:27 pm
by w00dzy
Cheers, I have moved the shock res to under the seat.. bit neater..
Not sure what to do next now..
Maybe carbon fiber rear huger and an updated front fender in carbon ;)
Posted: Tue May 18, 2010 6:25 pm
by lloydiecbr
:sshh: lights lights lights lights lights :sshh:
Posted: Tue May 18, 2010 6:51 pm
by w00dzy
yup that's true.. need to write a list ;)
Posted: Tue May 18, 2010 8:27 pm
by lloydiecbr
once you start a lits it never ends
