nc35 carbs on a 30
nc35 carbs on a 30
ive put some 35 carbs on my 30 it starts ok the dies the main jet sizes are all 118 any ideas ? ps one of the pilot air screws is missing the little rubber and steel washer can you still get these new ? cheers
Re: nc35 carbs on a 30
Yes - std RVF jet sizes are 108....so try going down a fair few!!
- skinnydog0_0
- Bike owned: Penny Farthing
Hi rgstu,
I am doing the same thing myself, if i have any sucess i will let you know. Do you have standard everything, air filter exhaust and so on?
- skinnydog0_0
I have had my bike out this afternoon, and it seemed okay, i am running a micron race can and 110 jets. the airbox is standard the filter is slightly free'er flowing. I have set the pilot jets to 1 6/8 turns out and it seems to be okay, starts without the choke and will idle okay.
I reckon start at standard setup and work from there.
yep its using the standard airbox but i have a vance n hines can . i will drop down to 110s to see if that helps can i still get the wee rubber washer and steel washer thats sits on the end of the pilot air screw? i stripped out the pilots on a old set of nc30 carbs i had lying about and there were none on them ! cheers stu
- skinnydog0_0
To be honest i dont know about the washer and little rubber. Best to have a word with Rick Oliver he may have some, or David silver spares.
