nc35 carbs on a UK spec nc30 engine
skinnydog0_0
Bike owned: Penny Farthing
Post by skinnydog0_0 »
Hi all,
Has anyone ever run a set of 35 carbs on a uk spec 30 engine?
I understand that the uk 30 engine has 120 + 122 jets in the standard carbs which are bigger that the standard jets in the 35 carbs.
Should i use the 120 jets for this set up?
The engine is standard, and i have a micron race end can.
any advice or thoughts much appreciated.
Re: nc35 carbs on a UK spec nc30 engine
Been covered many times on the forum, try a search theres many different setups you can go for but in general it'll give you a better midrange.
skinnydog0_0
Thanks Drunken Munky, i will trawl through see what i can find :smile:
superlite
Bike owned: TLS, LB80 x 2
Post by superlite »
skinnydog0_0 wrote:Should i use the 120 jets for this set up?
No. NC35 carbs run smaller jets that NC30 carbs. You want to be around the 110-112 ballpark.
'Take it to the Back'
CRM
Admin NWAA
Admin NWAA
Post by CRM »
yes i have and in short
3/4 yamamoto system
UK NC30 & Jap spec bikes
Both responded very well with std air filter
and 110 and 112 setup
nothing else changed, pulled like fook.
post in the V4 section for a speedier more accurate reply
skinnydog0_0
Thanks guys,
I have up jetted to what the uk 30 carbs have 120 and 122. I haven't run the bike yet, but sounds like i may have been a little over generous.
I will take your advice and post thgis in teh V4 section :grin:
