bullet connectors question
Posted: Mon Apr 19, 2010 7:01 pm
i am removing the multiplug for the regulator on my nc30 as the plug at present only houses the red and green wires someone has previously removed the 3 yellow which bypass the plug now. intend to solder on new spades for the r6 reg was wondering if it would be ok to solder bullet conectors for the red/green wires and do away with the plug altogether or would they create a resistance or melt
the multiplug has a yellow spade missing and has signs of burning previously probably the reason someone has bypassed it, the connection at the plug for the red wires is suspect hence the reason for asking folks.
