Knocking noise from front end, NC30
Been getting a slight knocking noise from the fron end, done the obvious and checked for anything loose or in the way but found nothing, both wheel and head bearings seem to be ok. I can also get it to make the noise by holding the front brake on and bouncing the front end. the knock is always at the bottom of the fork travel so could this be bottoming out? Ive seen rick does an anti bottoming kit but im fitting his upgrade kit soon so will i need this anti bottoming kit aswell?
Only thing is whilst riding the noise is there but the forks are nowhere near bottoming out, any ideas?
hunter
Re: Knocking noise from front end, NC30
Post by hunter »
Sounds like fork bushes.
superlite
Bike owned: TLS, LB80 x 2
Post by superlite »
Loose front guard mounts?
'Take it to the Back'
viper_biker
Post by viper_biker »
superlite wrote:Loose front guard mounts?
+1
Ive checked these and cant seem to find a fault with them but then ive heard of packing something out with a rubber washer with regards to the mudguard but looking at it i cant see where????
superlite
Post by superlite »
A couple of layers of electrical tape on the inside does the trick.
On the inside of where matey??
superlite
Post by superlite »
On the inside of the guard mounts. Remove the clips and slide them up the forks, add tape and then re-fit. Jobs a gooden :up:
Old Painless
Post by Old Painless »
My CBR600 was doing something like this, turns out the rubber bushes on the calipers were worn and the caliper was moving. Try wobbling the caliper with your hand.
banoffee
Post by banoffee »
mine does this, it's the mudguard mounts. dont notice when wearing earplugs and/or with the race can on so ignored it
