rectifier problems
rectifier problems
hi
does anyone know the correct output from the generator to the rectifier ..need to test this
just had rectifier go again
.the front right connection as you look at the side of the bike has burnt out.. fortunately i had a spare rectifer in garage
..but i want to test all voltages to see if i have a bigger problem
cheers
in advance
martin
cheers
in advance
martin
- superfourben
Re: rectifier problems
Go to this website and download the fault finding chart, it has all the details you need for testing the rectifier. Also, check all your connections and make sure they are clean as these can often be the start of the problems.
http://www.electrosport.com/technical-r ... -guide.php" onclick="window.open(this.href);return false;
cheers
will try this tommorow
martin
martin
