Fitting Rear Shock - should I grease the Shaft of bolts??
marty400
Post by marty400 »
Hiya All,
I've fitted the Refurbed Rear Shock to the CBR400!
1 question:
Fitting the Rear Shock - should I have greased the Spindle of the Mounting Bolts??
The Bearings were pre greased by MCT suspension. I assumed that was enough.
I didn't want to slap loads of grease anywhere near the mounting bolt threads. I Just cleaned the whole area, the bolts, and the threads, and I carefully appiled Thread lock to the Mounting bolt threads.
My neighbour says not an issue, its the bearing that move, and thats what needed greasing.
Hope you can advise.
Martin
LUCAS
Bike owned: NC29 and NC35
Re: Fitting Rear Shock - should I grease the Shaft of bolts??
Post by LUCAS »
Personally i would put a thin later of grease on. I wouldn't put anything like that in dry
marty400
Post by marty400 »
ahhh... should just google!
http://www.desmonorthwest.com/tech_a...16-996-998.pdf" onclick="window.open(this.href);return false;
Answer - yes, should do it!
Drat, I'll do another time though in April, if rainy weekend - want to ride her tommorow morning!
LUCAS
Post by LUCAS »
marty400 wrote:ahhh... should just google!
Too right - just go and ride it tomorrow :P
Another start to a working week again before you know it!
