renthal rear sprockets question
Posted: Sat Apr 03, 2010 5:53 pm
by Dynamohum
can anyone tell me which way the rear sprocket fits :?: fitted mine with the stamped side out it came without instructions so asumed the face with the sticker and size faces outward am i incorrect :?
Re: renthal rear sprockets question
Posted: Sat Apr 03, 2010 6:27 pm
by Polisher
davethetrucker wrote:can anyone tell me which way the rear sprocket fits :?: fitted mine with the stamped side out it came without instructions so asumed the face with the sticker and size faces outward am i incorrect :?
You're bang on Dave
Writing and sticker face outwards.
Posted: Sat Apr 03, 2010 6:47 pm
by Dynamohum
Writing and sticker face outwards.[/quote]
thanks polisher, just changed chain as other one was an ebay purchased racelink chain and appeared to have a tight spot which gave problems getting tension spot on. after changing it to a new rk x ring i seem to have the same problem noticed slight wear on the outside edge of the sprocket teeth [ only done about 500mls] i am sure g/box sprocket is right way round so problem could be rear hub/bearing possibly.
Posted: Sun Apr 04, 2010 8:54 am
by banoffee
so does the lip face in or out?
Posted: Sun Apr 04, 2010 10:47 am
by Dynamohum
banoffee wrote:so does the lip face in or out?
thats what i was unsure of the flat side has the size and renthal sticker on it so assumed it was the outward side and the lip side inner :?: if fitted wrong way would give alignment problems as i noticed slight wear on the outer side of the teeth , going to remove sprocket carrier as i think i may have stupidly fitted thrust washer on the wrong side which may be my problem :oops: i have both washers between hub nut and hub does the thinner one go behind the sprocket carrier :?:
Posted: Sun Apr 04, 2010 12:31 pm
by royster81
they offset towards the wheel, lip inside.
Posted: Sat Apr 10, 2010 12:54 pm
by banoffee
guess whose was on the wrong way round :?
now sorted, got to be good for another bhp or two at the back wheel :grin:
Posted: Sat Apr 10, 2010 12:56 pm
by brooky
lip inward, assuming you havent got a 750 rear wheel?
Posted: Sat Apr 10, 2010 8:38 pm
by Dynamohum
thanks fellas it was on lip to inside all ok that way, was unsure so thought i would ask the bretheren . changed hub/bearings sorted thanks :grin:
