Speedo drive
Speedo drive
Hi its my first post on the forum so please go easy on me
lol Right basically I've had my vfr400 nc30 since may, about a week before I put her away for winter the speedo stopped workin. Over the winter I stripped the bike back a bit for some tlc valve clearences etc. When I was tryin to find the problem with the speedo I found that the plastic drive that goes on the sprocket was fubared it was rounded off and I also found that the front bolt holding the sprocket on was loose!!!!! That could have been messy! Anyway thinking that caused it to round off I put thread lock on the bolt an torques it up, an fitted a new drive. Finally finished the bike last Saturday took it for a ride, and everything was brilliant untill I had done about 70km an now the speedo has stopped working again, it's the plastic drive that has rounded off again, this time the bolt is still tight though! Any ideas? I was thinking that it could have bent the metal drive that goes into the plastic drive slightly when the bolt was loose? Or mabe a stiff speedo cable? Any ideas greatly apreciated cos I like to know what speed I'm goin especially with all the speed cameras round my way!!! Lol
- Deviant400
Re: Speedo drive
the chances are its the speedo cable, could be the drive that bolts to the cover but im sure if you clean that bit and wang a bit of WD40 in there get things loose that would be fine, my money is on a stiff cable,i replaced mine twice and then got a new cable been fine since, the little white plastic things are crummy and dont take much to kill um, theres someone on here does alloy ones , but if the cable is good and the drive bits free and workin then you should be fine with the standard plastic one
viewtopic.php?f=62&t=27307
Re: Speedo drive
if you find you speed ocable is knackered, i have just bought a box of nc30 bits and there is a speedo cable in there. is used but looks good, doesnt seem stiff or stuck. no good to me as i need a longer cable for my '30.
if you need one pm me say £6.50 posted?
Re: Speedo drive
Thanks guys will try a speedo cable first then with a new plastic drive, an thanks for the offer, but I can get a genuine brand new one for a few quid more an I can then deffo rule that out as not bein the problem lol
Re: Speedo drive
thats no prob, i was guessing the postage at around £2.00 and that can be the killer sometimes.
i will keep it in the box with other bits.....you never know when or how it maybe needed!
Re: Speedo drive
I replaced the speedo cable an the little plastic drive an only done about another 400km an it's bloody broke again!!!! Lasted much longer than the last one but still can't see what is causing this, I know the bits arn't expencive but it's gettin that way with how many I've brought now!!!! Lol anyone with any other ideas?
Re: Speedo drive
Over-tight / no grease / stiff speedo (siezed)Andy_998 wrote:I replaced the speedo cable an the little plastic drive an only done about another 400km an it's bloody broke again!!!! Lasted much longer than the last one but still can't see what is causing this, I know the bits arn't expencive but it's gettin that way with how many I've brought now!!!! Lol anyone with any other ideas?
If it's rounding off it's not together right or something has siezed stiff (usual problem)
