Reg / Rec block connector
Posted: Tue Mar 23, 2010 4:41 pm
by emto
Does anyone know if the block connector (NC30) to the reg/rec is something readily available off the shelf or does any other model block fit? One of my block pins is fairly fried, I've replaced the reg/rec already, but don't want further hassle.
Re: Reg / Rec block connector
Posted: Tue Mar 23, 2010 4:46 pm
by pugparcels
pretty sure the r6 98 - 04 rectifier is compatible. sure i will be flamed if wrong
Posted: Tue Mar 23, 2010 6:56 pm
A block is a block - get both halves of a suitable 5 spade fitment and get it fitted...
Posted: Tue Mar 23, 2010 9:00 pm
by Cammo
It's not an off the shelf part, the honda plug uses 2 different sized plugs on the reg/rec.
You can get rid of the block altogether and solder on the 2 diffferent sized female spade plugs to suit the honda reg rec.
Edit: Just searched for 'regulator plug' on uk ebay, there's a heap:
http://motors-parts.shop.ebay.co.uk/Mot ... 86.c0.m282" onclick="window.open(this.href);return false;
Posted: Tue Mar 23, 2010 11:35 pm
If your joining wires, make sure there clean, twisted together and SOLDERED properly.
If you just twist em up or use connector blocks the extra resistance these place will soon make it get hot and melt!
Posted: Wed Mar 24, 2010 10:43 am
by RickOliver
Those plugs are available - there`s only one supplier in the UK who has them (and he knows it so he will only sell them to trade customers and charges us £5 a time). I keep a few on the shelf so mail me if you want one...
RickNC30(at)googlemail.com
