Please help, carb O-ring sizes required!
Posted: Tue Mar 23, 2010 11:30 am
I am from South Africa so importing the o-ring can be quiet expensive. Can you please help with the o-ring sizes as I am trying to source them locally to save cost.
From Tony sleep website I got this list, please advise if correct
ID Cross section OD Hardness Quantity
Main jet 6.07mm 1.78mm 9.63mm 75°Shore'A' 4
Float perch 7.65mm 1.78mm 11.21mm 75°Shore'A' 4
Slide holder 10mm 1mm 12mm 75°Shore'A' 4
Idle screw 2.5mm 1mm 4.5mm 75°Shore'A' 4
Are there any additional seals/o-rings I should get?
Many thanks
Nevashen
Many thanks
Nevashen
