Page 1 of 3
LED indicators - basic question
Posted: Sun Mar 21, 2010 11:33 pm
by Cammo
Do I need some sort of resistor module to get LED indicators (front and back) flashing at the standard rate on an nc30?
Yet to buy some, want to get everything I need at once.
Tried a search but couldn't find what I was after.
Thanks.
Re: LED indicators - basic question
Posted: Mon Mar 22, 2010 12:56 am
by eamer1989
you will indeed cam, well depends they will flash slightly fast but not quiet a fail over here :)
Posted: Mon Mar 22, 2010 8:31 pm
by mart
i think you can also buy a flasher relay to suit instead of 4 resistor blocks
Posted: Wed Mar 24, 2010 10:02 pm
by stunc30
ive seen replacement relays for led indicators as well but havnt tried them yet but if u use the large type resistor u should only need to use one as the whole indicator circuit works on resistance they do get quite warm though hence surrounded by heat sink i would mount it to frame. personally i would get replacement relay ;)
Posted: Wed Mar 24, 2010 10:08 pm
by ozracer
You need an electronic flasher relay. The flash rate is set by the electronics in the relay and doesn't rely on the heating and cooling of a bi-metalic strip like in normal relays. Easy to get from eBay or auto parts shops/auto electricians.
Posted: Wed Mar 24, 2010 10:22 pm
by hardnutdvd
Halfords do them too...
Posted: Wed Mar 24, 2010 10:54 pm
by Cammo
Thanks for the replies, a new relay it is.
Posted: Mon May 10, 2010 4:31 am
by Cammo
Update:
Took the easy option: LED flasher relay installed... fail! All 4 indicators flash at the same time. Must be something to do with the extra current going through the wiring with the led's installed.
I took the dash indicator light out even, thinking that this was the only part of the circuit that links the left and right indicator system, still no joy.
Have purchased some resistors to install, will install them in the next few days.
Posted: Fri May 14, 2010 11:14 am
by Cammo
Cammo wrote:Update:
Nice quote.
Solution:
For peeps thinking of installing led indicators the easy fix is to fit an led flasher unit as suggested above, and remove the dash indicator lamp so that the left and right circuits are separated. There are ways around this and still being able to use the dash lamp, but some electronic components (diodes) are involved.
I just tossed the bulb... only Sunday riders tend leave the indicators in. Oops that could be me! :oops:
Posted: Sat Jun 05, 2010 3:43 am
by Cammo
Update: Decided to get the indicator dash bulb working.
On the NC30 when you convert all indicators to LED's, whenever left or right indicators are selected all 4 will flash. The dash indicator bulb joins the left and right circuits together. This will happen regardless of which type of flasher relay you're using.
This isn't a problem when using the standard indicator bulbs because there isn't enough current to flash all 4 incandescent bulbs, but it is a problem with LED indicators because they require so little current to work.
3 solutions to this:
1. Remove the dash indicator bulb like I did above, but you won't know if you've left them on. Not a safe option.
2. Fit heavy duty resistors to all 4 indicators to soak up the extra current in the circuit. These can get very hot (because of all the current that they're resisting) and are a very dodgy solution IMO.
3. Fit diodes to the indicator dash bulb circuit to act as one way devices for the current. This is generally how oem setups get around the issue, so I chose to use this method.
You'll need to buy 2 IN4004 diodes (or IN4005/IN4007). They cost me a grand total of 5c each from an electronics store. Soldering and heatshrinking the joins is a good idea also.
Didoes:
To fit them, find the wiring behind the dash for the indicator bulb - it's a light blue wire and an orange wire that goes to the bulb holder.
Cut them, leaving a good inch or so of wire on the bulb holder. Install the diodes (making sure they're around the correct way - silver band on the bulb side), and run both of these to just one of the bulb holder wires.
Run the other bulb holder wire to a suitable earth (there are several suitable locations on the back of the clocks - green wires).
Diagram:
Test it before you solder it and heatshrink it all together. All done!
