Yet another carb problem!
Posted: Fri Mar 19, 2010 3:35 pm
Right, this is a little strange! Had a few sets of carbs kicking around for a while and the ones I sorted for my winter project bike worked fine but cosmetically looked crap. Yeah, yeah I know their hidden but I wanted a cleaner set on.
Anyway, I did all the carb mods as usual. 118/120 mains, drilled slides, extra washer etc etc but decided to use the diaphragms that were in the carbs as they looked ok, and I couldn't be arsed to swap them for the ones out of the previous set. A bit dry and very slightly shrunken but thought I got them to fit ok. Back on the bike, float bowls filled and away she fires. 4K rpm on choke for a bit, slowly off choke but revs stay put. At this point I just let it warm up to see what happened but the revs still stayed put. So i'm thinking induction leak or maybe I have simply done something wrong (even though I know the carbs quite well).
Off came the carbs again. Had a look at the diaphragms and sure enough I hadn't seated two of the four in the groove. So I swapped them for the flexible 'wet' set and assumed that was the problem. Turns out I still have the same thing. Revs hanging at at least 5K RPM and staying there. If I blip the throttle they go even higher and hang.
Im stumped and, even though this is a set of carbs I got off ebay a while back and are unproven (at least to me), what else is there to go wrong?
I know I have them mounted correctly on the rubbers. Sure the diaphragms are now seated correctly and I haven't made a schoolboy error like bad throttle cable adjustment.
Any ideas before I bin them?
