Brembo Calipers on NC30
Posted: Thu Mar 18, 2010 1:22 am
by matt_nc30
Hi, would it be the 748/916/996 type calipers that can be made to fit?
I take it i would need, Calipers, brackets, m/s cylinder, resevoir & maybe different lines?
i
would be greatful if some one could tell me what parts are actually needed all together to make the conversion?
& how well do these calipers work on the standard nc30 dics?
Thanks all! ;)
Re: Brembo Calipers on NC30
Posted: Thu Mar 18, 2010 1:24 am
by matt_nc30
Would these be any good?
http://cgi.ebay.co.uk/Ducati-748-748R-9 ... 439e0e52ff" onclick="window.open(this.href);return false;
Posted: Thu Mar 18, 2010 6:48 am
by force-v4
hello not sure which of the brembos you'd need as i didnt go that way but i do remember them being 65mm fixing points.
yes, you need different brake lines, ideally a bigger m/c or something to suit - there are loads of options & you'll need some caliper fitting brackets for the fork legs.
Rick Oliver sells the brackets you will need.
Posted: Thu Mar 18, 2010 11:48 am
by micpec
Hi there, yes, 65mm mounting type Brembo calipers are the ones you will need, and of course some alloy brackets (ask Rick Oliver).
Used to have the 2-pad type 65mm calipers fitted on ex-NC30, these came from a Ducati 916 model, you will need some longer braided lines and as for mastercylinder.
I found the Brembo adjustable m/c type PSC16 goes perfect.
The ones pictures in that fleabay item...are the better (read: more expensive ones) as these are the 4-pad type (4 small brake pads used per caliper!).
Posted: Thu Mar 18, 2010 11:59 am
by matt_nc30
thanks for replys guys
So this is a worth while mod in terms of braking power gains?
Posted: Thu Mar 18, 2010 12:34 pm
by viper_biker
matt_nc30 wrote:thanks for replys guys
Simply, yes.
Posted: Thu Mar 18, 2010 10:53 pm
by Riley
Hi Matt,
I can supply you with a good set of 65mm Brembo goldline calipers with good pads (Ducati 996) for £90 delivered if its any use to you.
Edit: coming to think about it I have matching Brembo 996 mastercylinders available too, in the same parcel (no additional postage cost) £70 for just a mastercylinder (no res. pot, lever etc, or £90 for a complete unit.
Failing that I have a complete Ducati 996 front end and fitting kit for the nc30 - but that would be a substantial amount of money (Galfer braking wave discs, gold nitrate Tin forks, wheel, braided lines mastercylinder, yokes, calipers, c/f front guard, hinged clip ons, etc).
Cheers Paul.
Posted: Fri Mar 19, 2010 12:31 am
by matt_nc30
Riley, i am interested in the calipers, master cylinder and resevoir. Any chance of keeping them for me untill the end of the month? :pray:
How much would you be looking for for the complete front end, probably too much for me :P but just curious.
