Vacuum pressure is....?
Strikmabill
Post by Strikmabill »
While I'm waiting for my Morgan Carbtune to arrive :grin: can anyone tell me the correct vacuum pressure for my 93 3tj? I have the manual that I'm guessing everyone does (FZR400SP_3TJ-ME1_91.PDF) but it's for the SP model. Besides it shows two different values, 145mmHg on page 16 of the pdf file and 230~270mmHg on page 35. Don't want to cram the forum with new posts but couldn't find anything with the search option. Thanks in advance.
Taggyd
Bike owned: fzr 400 3tj x 2, cbr900rrs
Re: Vacuum pressure is....?
Post by Taggyd »
the one ive got says 145mmhg or more! its for a 1992 rr
Strikmabill
I guess I'll find out when i get to it. Thanks Taggy.
Strikmabill
By the way, i can't find where to fit the hoses to the carbtune. I took the carbs apart to clean them and can't find anything on them to connect the carbtune hoses. I think 1WG inlet manifolds have little tubes sticking out and that's where you're suppost to connect the carbtune hoses right? But I can't find them in my 3tj inlet manifolds.. can you tell me where they are? Thanks.
Post by Evilchicken0 »
Isn't there a screw in the manifold ... or am I thinking of the 1WG
Strikmabill
I'll have to look for it better but I didn't see one. And I had the carbs off for the last 2 months give or take as I didn't have much time and my valve check was a nightmare.
These are from a 1WG I think
But I'm almost sure my inlet manifolds don't have that bit sticking out. Some carbs have those bits on top but mine sure don't. I'm guessing you racers out there know where to plug the hoses in, enlighten me please!
Cheers.
Strikmabill
Ok good news and bad news. Good news is I'm an idiot and it's obvious just by looking at the inlet manifold which screw it is that must be removed to screw in the adaptor for the carbtune hoses. Bad news is they're completely stuck. Sprayed some wd40 on them, only on the outside, and we'll see if it does anything tomorrow. Is it a good idea to use an impact wrench here? Are 17 year old manifolds able to take the beating? Took some pictures (with my phone because my camera died the minute I turned it on)
Viewing from rear to front of the bike
Viewing from the top, where carbs sit
Now all i need to do is get them out :twisted:
Taggyd
Post by Taggyd »
try taking the rubber off and heating it up?
Strikmabill
With what? Hair dryer?
bendy3
Bike owned: FZR400RRSP FZR400 HYBRID RRSP
Post by bendy3 »
I had em stuck in once, I just used an impact driver. Didnt wack it though, a bit of finesse req. ;)
