NC30 Indicator problems
IanP
Post by IanP »
Hi All,
Was wondering iof someone could shed some light (no pun intended) on my indicator problem.
My rear indicators are not working, i've checked the bulbs also checked all the wiring and there is a current going through and the flashing but the bulbs do not flash one bit. When I was taking one of the bulbs out it flashed for about 0000.1 Seconds but it doesn't seem like a lose connection because the tester was flashing fine, I'm stumped to be honest.
ibby4585
Bike owned: SP's
Re: NC30 Indicator problems
Post by ibby4585 »
I would say its definately a loose connection. Take the workings out use some sandpaper on the contacts then wd40 in the spring mechanism. and it should work . Ive just done all mine and they are fine!!
