vfr tyers what size/make
Posted: Thu Mar 11, 2010 9:20 pm
by woodward1248
what size will the vfr 400 nc30.
im thiniking of buying BRIDGESTONE MOTORBIKE TYRES BT021 120/70-17 & 160/60-18
188pound
Re: vfr tyers what size/make
Posted: Thu Mar 11, 2010 9:50 pm
by Polisher
The 120/70 will more than likely rub on your front mudgaurd, it should be a 120/60
The 160 at the back you may get away with. I run a 160/60-18 Avon Azzaro Storm but had to have4 tiny spacers made to stop it fouling the chain and the profile is not ideal for the bike
I'm going back to a 150/60-18 rear with a 120/60-17 front. I'm going to try the Dunlop Alpha A10s rather than the Bridgestone BT090 ( although I believe that there is now a BT090 PRO for the rear that is quite new out)
Stick with what Honda put on, they didi it for a good reason
Posted: Thu Mar 18, 2010 7:26 pm
by Mikiboy
You want H rated tyres. 090's or Alphas are designed for 400.
Posted: Fri Mar 19, 2010 9:21 am
by royster81
Polisher wrote:The 120/70 will more than likely rub on your front mudgaurd, it should be a 120/60
it shouldn't foul the mud guard but what it might foul is the V piece if you forks are bog stock and in need of a refresh .
most of my VFR's run or have ran 120/70 and the only forks to have let the tyre rub the V piece were tired 89 spec forks.
Posted: Fri Mar 19, 2010 7:44 pm
Just incase.. the standard tyres are
120/60/17
150/60/18
