radial master cylinder
nick
Thinking of an upgrade for the front, saw these on flea-bay
http://cgi.ebay.co.uk/front-brakes-Mast ... 5638a5f31b
Not sure if the quality will be any good at that price........
Re: radial master cylinder
If you can't afford the real thing, don't buy a fake.
- cagiva996
ive got a brembo radial master cylinder 16mm/18mm with lever if your interested-bought it off a freind for a project and never used it.the adjuster wheel is missing but you can still adjust the lever span,just not on the move,you can buy spare adjusters from most brembo dealers.i paid 75 quid for it,you can have it for that posted if you want it.
nick
Looking for a 19mm 18 or 20 ratio, think a 16mm will be too small
hunter
What calipers are you using nick.
jacknell
nick ive a genuine 19x20 radial brembo with flip up lever if any good.
nick
Standard 3TJ 4 potshunter wrote:What calipers are you using nick.
I use a 19x20 on my 3TJ with braided lines and HH pads, it stops hard but the lever's a bit wooden.nick wrote:Standard 3TJ 4 potshunter wrote:What calipers are you using nick.
hunter
Most radial braked bikes run 4 pots,some with bigger pistons than others,
I don't know what size master is fitted as standard equipment on the 3jt,
The NC30 is fitted with i think a 5/8" metric 16mm,
So if you wish to go bigger 18mm would be fine,going to big can give you the wooden feel like
evil said.
evil said.
nick
So, do you think a 16x18 will be any good? I'm looking for an improvment over standard, already got braided lines and decent pads.
