Pipes any ideas ??!!
Bigjim
Bike is going into the garage to have the restrictors fitted as I couldnt get the carbs off
When I was under the tank I noticed there was no breather pipe or over flow pipe for the tank
The originals are no where to be seen !
Is it as simple as running two pipes down, on the parts pdf there is some sort of joint but I coulnd figure out where it was going ??
Jim
Jim
chmod-uk
- Bike owned: cb400sfr
Re: Pipes any ideas ??!!
Make sure they aren't already there, maybe they've dropped down a little out of sight. I wouldn't worry about it, i took the tank off mine t'other day and the pipes were there but not connected for some reason, just put them back on.
Bigjim
Def not there !! WIll get some pipe on them on see how they run
