engine help on swaping
fzrwayne
Bike owned: fzr400r exup
Post by fzrwayne »
ok girls lol im poss to be going buyinga thundercat engine carbs and down pipes to put in my fzr400r exup 1wg. i understand that the engine goes rite in with noproblems but could any of you tell me something i should know about getin it to fit to getin it to go down the road safely? i have never done this before so i am hopeing i dont make a balls of it and mess it rite up. thanks alot fellas ;)
Taggyd
Bike owned: fzr 400 3tj x 2, cbr900rrs
Re: engine help on swaping
Post by Taggyd »
get a mate to help! did one of my engines on my own and it was a bit painful! just make sure you tighten everything up check the alignment of the sprockets take lots of pictures of where things route like wires etc. might need to beef up front forks, def. refresh them and make sure your brakes work! do all the usual pre ride checks and fluid top ups then try it! slowly! :grin:
i found it easier to put the rear most mount in and pivot it up from there get as much out of the way as possible before you start!
hunter
Post by hunter »
All you want to know is here.
http://www.400greybike.info/newforum/vi ... =37&t=4143" onclick="window.open(this.href);return false;
cagiva996
Bike owned: 2 FZR4/6,FZS600,YZFR1
Post by cagiva996 »
do the t/cat motors go into a 1wg?,i only mention it as the t/cat motor hangs from the frame spars and the 1wg has an ally cradle.i always thought that you needed a pre 94/95 fzr600 (3he i think) to be compatable with the frame-though i may be wrong but might be worth checking before you part with any cash
Post by Evilchicken0 »
Ithink they go in because Yamaha kept the moulds similar. But I'm not sure the sporkets line like the 3HE motor.
The T'cat carbs are different to your bike so your airbox won't fit, and it won't go under the tank cover. They also have a throtle sensor which will cause your revcounter to do weird things.
The 600 3HE motor will run on your CDI although it's better with 600's. The carbs are similar to your 400 and so your airbox will fit ... although you'll need to space the tank shroud up a bit to fit. Because the egine casings are common the sprokets line straight up so there's no problem.
Use the 3HE engine
hunter
Post by hunter »
I think you have to make a new frame cradle,
To be able to fit the foxeye motor in the 1wg frame.
No - It will fit but it's just a bit more mucking arround than a 3HE. Given the airbox problems with the 4JH the 3HE is a much better bet
Taggyd
Post by Taggyd »
oops, didnt realise it wasnt the motor i was thinking about! :oops:
sparkles
Bike owned: 1990 fzr6 3he with a 4jh engin
Post by sparkles »
cagiva996 wrote:do the t/cat motors go into a 1wg?,i only mention it as the t/cat motor hangs from the frame spars and the 1wg has an ally cradle.i always thought that you needed a pre 94/95 fzr600 (3he i think) to be compatable with the frame-though i may be wrong but might be worth checking before you part with any cash
I have a 3he (fzr600 1990) with a foyeye (4jh) thundercat engine in it and all the engine mountains are the same as the 3he
The only difference is between the engine mountains is there are some on the barrels which some of you 400 people with a plate use to fit in to your frames.
With the 4jh engine 3he engine the chain allinment is different so what i intend to do when i can is put the top end of the 4jh on the bottom end of the 3he engine which means the chain is allined and i have been told it makes it in to a 660 as one engines stroke is shorter then the other.
I have kept the 3he wiring loom and wired the 4jh cdi in to the wiring loom and i have a spare 3he loom as well
Not to sure about the studs / oilways lining up with the 4jh / 3he engines and you might need a special spacer to raise the barrels to allow for the longer stroke.
how much a sprokets out of line ???
