xenon headlights
jamiep
Bike owned: honda vfr 400r nc30
xenon headlights
Post by jamiep »
Please can someone ;) help i recently bought a set of xenon headlight bulbs for my VFR 400R NC30 however they do not fit the bulbs i was sent i slightly bigger than my originals they are the H4-501 55W bulbs! Does anyone know if these should fit or have i got the wrong ones?
banoffee
Re: xenon headlights
Post by banoffee »
if you want to fit H4 bulbs to a jap-import NC30 you need to fit a relay and then adapt the bulbs to fit.
am doing this soon...
http://www.vsource.org/VFR-RVF_files/NC ... mRelay.htm" onclick="window.open(this.href);return false;
http://cgi.ebay.com/ebaymotors/H4-Bulb- ... ccessories" onclick="window.open(this.href);return false;
You need some H4R bulbs from your local bike shop - 35/60 rated I thnk
Welcome to the site..
cbr400rrn
Bike owned: NC29 CBR600F
Post by cbr400rrn »
I bought these adapter rings from that same person. They must be busy as i have recommended her to a few people myself
CMSMJ1 wrote:You need some H4R bulbs from your local bike shop - 35/60 rated I thnk
Is that the same for nc35 headlights??
micpec
Post by micpec »
RVF400 standard light bulb is H4R
ah i see. so what about xenon bulbs for the 35?
vfrman
Bike owned: NC30, 1098s
Post by vfrman »
Yes. H4R is what the NC35 takes as well.
I have fitted a pair of no bullshit HID xenon lights to my NC30. They are bi-xenon with hi/lo and ballasts and ignitors.
I had to use H4 bulbs and modify the headlights to accept them. I also had to shorten the reflector assembly on the bulb itself to get it to fit inside the headlight.
They are bright as hell, and if I had to do it over again, I would have gone with a whiter light (I believe mine are somewhere around 6500K) and would also go all out and figure out a way to install projectors.
jamiep
Post by jamiep »
Thanks for all the info its has helped!!! any more uggestions other than fitting a new relay let me no!! :grin: thanks
jamiep
Post by jamiep »
Do the adapter rings work for the nc30? because it doesent say they are for the nc30 on the ebay link? thanks
