head bearings adjustments on 3tj
ARn13
i want to adjust the steering headbearings on my 3tj, had a look at the manual but the print out isnt that clear so i wonder if anybody can tell me the way to go about it, thanks.
Taggyd
Re: head bearings adjustments on 3tj
take the big nut off and tighten the bit underneath! c spanner is useful or a hammer and big flat thing that fits the grooves if you dont have one just be gentle!!
Taggy you neanderthal
Use a C-Spanner / Hook Wrench don't tap it round with anything because you'll damage the nut.
They don't need to be done up very tight so if you MOT Station told you to do it your only looking to take up the slack plus a little. If you can raise the front wheel off the ground (safely) then hold the fork bottoms and try to move them forward and back - any movement and you can tighten them up. If you get to the nut being tight and there's still slack then you'll need new bearings
Taggyd
thats why i have kevler knuckles on me gloves! stops me knuckles hurtin wen they drag on the floor!
ARn13
cheers for the info taggy and Mr. evil.
to do this job i have to take the top yoke off, yes? c/ hook spanner? can i get this from a motorbike parts shop? if cheap enuff i`ll buy it, if not might be goin the taggy`s way.
yup - I saw a c spanner in Hein Gerike today
oollit
- Bike owned: FZR400RR 3TJ, RF900R
The headstock bearings tightening torque is specified as 6NM.
I normally tighten them up until i feel a bit resistance , back the nut off then re-tighten the nut up about 1/4 of a turn.
You can get an adjustable c-spanner for less than a tenner, which is cheaper than having to replace a butchered nut if you go at it with a punch and hammer.
If the steering feels notchy after you tighten up the nut, then the bearings will need to be replaced.
I only please one person per day.
Today is not your day, tomorrow isn't looking good either.
ARn13
http://cgi.ebay.co.uk/CHROME-BRITOOL-AD ... 2c52dc7fab" onclick="window.open(this.href);return false;
this is the tool i be needing?
That's a bit big ... try somthing like thisARn13 wrote:http://cgi.ebay.co.uk/CHROME-BRITOOL-AD ... 2c52dc7fab
http://cgi.ebay.co.uk/NEW-DRAPER-ADJUST ... 5ad62e7726" onclick="window.open(this.href);return false;
ARn13
Cheers Evil, that was gona be my next Q? what size as there are a few, now i know.
