rvf 1 cylinder not firing
steve234
Post by steve234 »
Hi
I have had this rvf for a couple of years, last year the rear right cylinder didnt seem to be firing, pull the plug lead of it while its running it made no difference, checked and adjusted valves, calibrated and cleaned the carbs, new plugs. can`t really remember but all that didnt work but for some reason a while after it started working on all 4 again.
been out on it over this winter to keeping running ok but 2 weeks ago i started it and running on 3 again, this time i changed carbs,plugs,leads and coils and still it only runs on 3 and its that same cylinder, all plugs are a normal colour when i remove them. .
Any ideas??
Many thanks
Steve
eamer1989
Re: rvf 1 cylinder not firing
Post by eamer1989 »
i know this may sound weird but have you check charge rate and battery, my nc30 started working on 3 before and it seemed to be because of faulty reg, Is the cylinder which isnt firing getting a wet plug also ?
Compression on that cyclinder ?
steve234
Post by steve234 »
battery is fully charged, have a spare reg that i have tried on it and still the same. its always on this 1 cylinder, not done a compression test as i don`t have a tester, any other way of testing?
steve234
Post by steve234 »
Is it 8 or 10mm for the adaptors for the compression testers?
eamer1989
Post by eamer1989 »
think its 8mm cant rember are you local to hampshire i have one
steve234
Post by steve234 »
eamer1989 wrote:think its 8mm cant rember are you local to hampshire i have one
Thanks for the offer but a little far away, in Grantham Lincs.
I cant even find a tester on internet with a 8mm thread, are those push in ones any good?
arsey30
Bike owned: ftr223 650 bros
Post by arsey30 »
I had a similar problem recently.
Does the motor chime in at higher revs [6000]
The vacuum hose had a very small split where it fits the head adapter, but not enough to stop the fuel tap supplying fuel.
When I removed it I could see that the hose was so perished that it was stuck on the adapter and it had to be scraped off.
Dave.
