3TJ-00 IGNITOR WIRING??
Malignant Master
Hey there.
I have a Hitachi 3TJ-00 BB7208 DIGITAL IGNITOR.
Can someone provide me with info,as to where each of the different wires should go?
As this has been fitting by another onto my GSXR 400,and I'd like to redo the wiring.
Any diagrams, manuals, or anything would be appreciated.
Just a brief description
On the back there is 3 sets of wires,of which 2 are connector points
1st connector point has 4 connections.
2nd is a set of 8 wires: Green/Blue stripe, Black/Red stripe, Black/Yellow stripe,
Red/Blue stripe, White/Black stripe, White/Red stripe,
Red/Green stripe, Yellow/Green stripe
3rd connector point has 6 connections.
Re: 3TJ-00 IGNITOR WIRING??
I'd serously recomend you get right CDI for your bike.
The FZR's have a an exhaust valve (exup) which yours doesn't have. They also have a speed resrictor and if the CDI doesn't get a 0kmh signal from the speedo it restricts to 12.5k rpm in all gears.
Have a look at the manuals sticky thread there should be a wiring diagram in there.
