has anyone got a rear brake fairing 3tj spare?
drjkill
- Bike owned: Cbr1000rr,Nc35,3TJ & Rg500
im looking for the the rear fairing that
supports the brake light and also brake
light cause mine its little damaged
is a 4dx monster ugly light...
thanks
thanks
Re: has anyone got a rear brake fairing 3tj spare?
I've got a 3tj rear with the light ... but it's black
drjkill
well i have to tell you that for me will be fine just two days ago i won in fleabayEvilchicken0 wrote:I've got a 3tj rear with the light ... but it's black
an auction for a full black fairing with clocks and and headlight for 89 pounds
for me just a bargain, but the seller hasn't got that piece, so it would be brilliant.
could you send me photos to mcdunning@gmail.com but i can say yo that its nearly sold
finally i want to ask you were did you buy the carbon frame protectors and want brembo
brake is yours? a 16x18?...
thanx for all evilchicken
I'll get a pic to night - do you need the whole tail ?
I used a 19x20 cast unit but I think it's a bit to sharp for a 400 road bike - try a 19x18 to get a little more feel. They're a bit of a trial to fit though. You need some new hose from the res to the master. I had to cut the surround thing from the idiot lights the span adjuster still just touches but it doesn't lck the brake. I used a Ford DOHV sump washer to pack out the bar end weight, cos it's nylon and you need to enlarge the centre hole. I had a race brakehose (2 line) kit from a 1WG which I fitted on this but remember the lines bolt under the master so are at a different angle the standard TJ may not be long enough. Lastly when I used the 2 line pressure switch it was to long and I packed it with 2 copper and 1 more steel washer. My calipers are standard but fu(k does it stop !!!
http://www.iane.co.uk/brembo_racing_bra ... nders.html this guy is very good.
Oh I got the frame protectors off e-bay for about £30-40 they don't come up very often but are advertised on AA16 http://www.aa16.co.uk/a16yamahafzr400.htm try ringing him.
drjkill
im thinking to put the standart r1 '04 radial front brake because i think its enoughEvilchicken0 wrote:Oh I got the frame protectors off e-bay for about £30-40 they don't come up very often but are advertised on AA16 http://www.aa16.co.uk/a16yamahafzr400.htm try ringing him.
for that little 3tj calipers with a goodridge brake line should be working fine, we'll see!!!
drjkill
i only need the rear fairing with the braking lightEvilchicken0 wrote:I'll get a pic to night - do you need the whole tail ?
because the rear panels i´ve got them in a auction for 5puonds,
drjkill
evilchicken are you online?
yes .... now !!!
If Iwas online earlier it was because I didn't close down the window when I was at work.
I sent you an e-mail with a pic
drjkill
i would like to say that i received the picEvilchicken0 wrote:yes .... now !!!
but i didnt receive your email ive got another
mcdunning92@hotmail.com
mcdunning@gmail.com
thanx
