tuned exhaust system
buzzawak
My exhaust can is battered and brushed so I have been thinking about a replacement.
I have done a bit of reading about tuned systems. Problem with the FZR is it has a common chamber
so can’t really be tuned. So I was thinking about how to have a separate pipe for each cylinder but preserve the Exup.
I found this diagram of the 750 exhaust which has individual Exup valves for each cylinder.
It still has a common chamber after the valves but I think a rear flange could be made up
to lead into separate cans. This then would permit the length of the exhaust to be tuned.
Wondering if anyone has attempted this and if so that results were obtained?
Taggyd
Re: tuned exhaust system
sounds like a lot of hard work to me, buy a non exup set of stainless and get it set up properly i recon you'd get better performance.
Outright performance ... top end would be better with a non exup pipe but it would be at the cost of the bottom end ... which is why Yamaha put the exup in in the first place.
BDK do a full race system with an exup similar to the one shown but with a single valve.
If you want power just put a 600 in there.
Taggyd
was thinking of top end as perfomance, some reason i thought this was for a race bike!
Torque wins races
hunter
Torque wins races
Depends which circuit your at/
Taggyd
if the revs don't drop too low on the circuit, then it negates the need for the exup as it'll be open anyway! you'll lose a little on the start if you get it wrong but you only do one start in a race!
- Motorcycle Solutions
BDK sell this system for the fzr 400 models
buzzawak
Thanks guys, I have looked at the BDK system have emailed for prices.
Thinking it maybe chaeper to get the unit of a wrecked 750 but availability
would be a problem
P.S anyone got a dead tacho I can buy off them?
would be a problem
