cbr nc29 fork problems
cbrjack
Bike owned: honda nc29
Post by cbrjack »
hi all, i having a bit of a problem with my front forks. Ive stripped them down following to the letter the instructions in the haynes manual but im now stuck. The manual says to pull the two sections apart by holding one end in the vice and pulling hard on the other, using the lower bush to push the upper out of the fork bottom and therefore seperate the two sections. The problem is that this is not working, everytime i pull the leg out hard it simply sticks when fully extended and nothing happens. I perservered for a good 20 minutes but have made no headway, does anybody have any tips at all on what to do?
cheers in advance, jack
PARUS
Re: cbr nc29 fork problems
Post by PARUS »
Sorry, my video show all process - it's in russian but no so important..\
[youtube]http://www.youtube.com/watch?v=dlWbxltgppE[/youtube]
[youtube]http://www.youtube.com/watch?v=J6GTwZoXmY0[/youtube]
[youtube]http://www.youtube.com/watch?v=Z49p6z4FKpI[/youtube]
Also check this one - it's in english.
http://www.youtube.com/watch?v=5A0p2OH6 ... re=related" onclick="window.open(this.href);return false;
cress87
Bike owned: NC23 CBR400RR
Post by cress87 »
I had the same issue with my Tri-arm forks. It sounds like the lower bush is wedging itself inside the top bush rather than pushing it out. I ended up heating the top of the fork lowers and then trying again and the forks did eventually come apart. You will need to replace both fork bushes though as the coating will probably have been damaged now.
cbrjack
Post by cbrjack »
cheers that confirms what i thought. will heating the fork legs up have any effect on the steel? ive done this sort of thing before on tractors and things but never on a bike. How are they to paint too i was intending on painting them black, what sort of paint should i use??
lloydiecbr
Bike owned: VTR1000
Post by lloydiecbr »
black paint would help if you wanted to paint them black :whistle:
Wozza
Post by Wozza »
Get them powdercoated.
cbrjack
Post by cbrjack »
thanks everyone got the forks apart the second came apart like its supposed to the first came apart with a little heat, reckon im going to paint them, will take pics and post when done.
